opening a port for bitcomet does it vulnerability from the outside? I have a router and i have so other people can not hack my internet and use it. If i open my port will this allow other people to hack into my internet?
Technically Yes, that is probably the reason why you should always leave your Router’s Firewall enabled/On at all times. This helps to prevent DOS attacks and alike.
If you want your internet connection to stay safe, what you can do, is download PortTrigger (have a search for it via torrent search engines), and install it. This program will allow you to config the times when a specific port is open or closed.
I’ve opened many ports on my router and never had a problem. Like soraiya said just make sure the firewall is still enabled on the router. The only reason that opening a port becomes unsafe is if you have something on your computer that a hacker can communicate with, ie. spyware, trojans, etc.
