Other torrents
Does anyone know if there are other torrent sites that can be used with bit comet that are free like the four that are in the search field in bitcomet? I am new at this learning on my own with no huge computer skills.
There are hundreds. Most of them are very small though.
Many people don’t bother using BC’s built in search function, or its included browser, at all. It’s just a web browser, and a stripped-down version of one at that.
So just use your normal web browser instead. When you find a torrent whose contents you want, download the torrent file and save it to disk in your default torrent directory, then use BitComet to open it. When you find a torrent site you like, just bookmark it as you would any other site of interest.
http://www.torrentz.com
http://btjunkie.org/
http://www.geotorrents.com :wink:
