over uploading!! 1.14-1.13
hi everyone how u doin?
look guys i got this silly problem, i got my port opened n i have an over uploading, like i have all the tasks with 0kbps uploading while u watch the speed scale reading over 400 kbps some times, n this is completely unbelievable, this is totally wrong n btw it takes the whole speed so i even can’t surf the net any more until i get the program closed.
wifi - win 7 - using ver 1.14 - opened port
any help would be appreciated.
I guess you missed the “Do NOT request help here” on top of this section. Here you can only report bugs in the program.
If you wand help you should post in the BitComet General Discussion.
Topic moved.
Hi!
What is your maximum upload rate? Go to Options, Long-time seeding and set the upload rate limit for long-time seeding to 10% of your maximum upload rate.
Have a nice day!
Just to add…
Whenever you have a question, you first have to provide what we consider the Essentials and be able to include the maximum amount of detailed information (speed test results, the settings that you’re using, which Tutorial/s you have followed, etc.) possible - the more, the better.
Oops!! i’m so sorry guys cuz i’m a new member so plz don’t blame me :slight_smile: any way i’ll never do it again, promise.
vasy i’m so thankful, i set the new value, hope it works :wink: thanx again.
OK, no problem mate!
Feel free to report if you encounter any other problem.
Cheers!
well, does this procedure effect on my normal upload rate?!!
No, it only affects long-time seeding. Normal bt uploading will only be limited by your global max upload rate limit if you have set that. It should be set to 70% of your TESTED upload rate to give a fast response to other peers and to have a less lagged internet browsing experience.
