Well I’m trying to download anrachy online with bit comet. I can start the download just fine and everything goes nicely, but then my pc just freezes. Everything just sticks.
What’s going on? and how do I fix it please? ![]()
I forgot to post this -
CPU - Intel Pentium 4, 3.4 GHz
RAM - 512MB
OS - Windows XP
Security Software - McAfee
If u got a graffic card or something that is too powerfull for yourcomputer it will freeze and after a while burn up,i had this problem my self and it stinks, the problem can bee that your pc gets too hot inside try buy cooling,i cant garantie that it will help but u should try
Thanks for trying. But it was McAfee that was messing things up. I’ve fixed it now
Good old McAfee Privacy Service.
