peer guardian
I followed what seemed like good advice and installed peer guardian. However once i had it installed, I could no longer log into the forums. I had to exit PG to log in and post this topic. Does anyone have any insight as to what might be the problem?
Ok
First there are only three lists you should be using, those are the p2p, spyware, & ad lists given during install. Do not use any of the lists from Bluetack.
Second, make sure you have block HTTP turned off. This offers good protection but it can really slow down some web sites.
this is good advice from dark shroud
pg2 though can be customised by advanced users, and it can be benificial to block http, and then use the perm allow function
however for the average user follow DS advice
It’s more than likely that Peerguardian had by default left the “Block HTTP” enabled.
Disable that function, and you should be able to access https again.
