Piece Map
Hi, I searched for this topic just incase if has been reported already, but was able to find it. Apologies if its already up. Since the latest update (version 1.53 64 bit) i haven’t been able to see any of the piece map, the tab is there, its just got nothing in it. I’ve been Bitcomet user for 10+ years now and this is the first time i’ve had to do this as you guys normally to a top notch job. I’m not complaining at all. I just thought i’d point it out if no one else had yet. Sorry i tried uploading a screenshot but for the life of me I couldn’t get it to work. Kept getting errors. Thanks again
Adam
You’re right - I hadn’t looked (I’ve no running downloads at the moment - just uploads) but the ‘piece map’ just shows a blank.
I did notice though that it appears for a moment when you switch files.
Same problem here, it flashes for a instant then just goes blank…
It’s been reported
