hi can anyone tell me how to setup bitcomet to run automatically everytime i connected to the internet? please help. B)
This is really not a good idea for several reasons, as you should be selecting what torrent you want to run, and not running multiple torrents at the same time.
If you are seeding, you should consider what ratio each torrent is at, as well as which ones need seeders the most, then run them in proper order.
It would take a very complex program to do this automated.
Also, its not a good idea to start and stop torrents, as this is harmful to the swarm. It’s far better to start your torrent yourself, and select when you want to switch to another.
