hi… i have a problem whn running bit comet. Aftr installing,i open bit comet but aftr 2 seconds this thing below came out and it happens to all three versions i dwnloaded 0.79 , 0.78 , 0.70 . Can anyone tell me wats the problem and how to solve it as fast as possible. PLEASE !!! thnx ! ^^
The contents of ERRORLOG.TXT might be of some help, but not without a lot more info about your system. How fast is it, which OS and which version, which video card, how much memory? Which antivirus are you using, and which firewall(s)?
You didn’t mention your firewall(s), but you do have an NVidia graphics card. So check to see if you have NVidia’s firewall running. Check in Control Panel /Add Remove Programs, and see if you have something like “NVidia Network Access Manager”. That’s caused a lot of grief for P2P.
Maybe unrelated but you are behind on DirectX, so you might want to upgrade that to 9.0c too.
You’ll note that I asked several questions before, to the originator of this thread. You interlopers, you need to provide the same info. Since there are now three of you, it should become really confusing, really fast. Which is a bad idea, and which is why I suggested, and still strongly suggest, THAT YOU DO THIS IN A SEPARATE THREAD.
