please help
Ive been using bitcomet for a while now and never had a problem until today when I opened it and a message read can not listen to port. Can anyone explain why please?
That means that either your firewall is now blocking the port, or that something else has already grabbed the port and is using it. That will happen if you’ve already got one instance of BitComet running and try to start a second one.
Would windows messanger do this?
Only if you set messenger and BitComet to use the same port. Not a good idea, that.
More likely it’s a firewall issue. Check if the port is open at www.canyouseeme.org
