i am trying to install need for speed underground 2, i get through the first installation but then it tells me to insert 2nd disk…what do i do, i have both disks downloaded, is there a program to run the “disk” that i have downloaded…same thing goes with heros of might and magic 5
Daemon tools. Then you might need a no cd crack. That should have come with the game. Check the readme or .nfo file. You open the .nro with word pad, IE, Opera, or notepad.
Assuming you’re using Daemon Tools, you’ve mounted the first disk image and run the setup program you found on the virtual drive, then got that message. You simply mount the second disk image. You can do it in the same virtual drive (probably easiest) or create a second virtual drive and mount it there, then you’ll have to tell the setup program to look in that new virtual drive for the second disk. They usually have some way of doing that.
