pls help
pls help i dont knw how to extract .bc extension files…i have downloaded some file but i cant extract them especially with the .bc extension files…i need ur help pls anyone…THANK U SO MUCH
i think those bc files mean they arent completely downloaded. im not sure though
it cannto be extracted still..what kind of program u use to extract d files??? winzip or winrar??? pls help me
In the settings guide, which you should have read, it discusses these files.
BitComet optionally appends an extension, “.bc!”, to downloads that are not complete. This is not some sort of encryption, and does not affect the file structure in any way. It just indicates that this is an incomplete download. Allow BitComet to finish downloading. When it finishes, it will remove the extension it added, and you can then open the file as you normally woulde, depending on what sort of file it is.
