PLZ HELP ME
i am using Bitcomet 0.67 and i used when it was new but any way my problem is when i open the bit comet
it stays about 5 min and close again and i resive these message ( 0.67bitcomet.exe has encountered a problem and need to closthe. we are sorry for the inconvenience ) and i restarted my computer and the problem still
Hi,
Though i’m not a professional icon in this forum … may i share my suggestion with you please ??
Well, if you encounter such error … i can simply suggest you to:
step 1> uninstall the BITCOMET (from START>CONTROL PANEL>ADD OR REMOVE PROGRAMS)
step 2> RESTART your PC
step 3> Now install BITCOMET again. (recommended new version)
step 4> Again RESTART your PC. (So that BITCOMET gets fully functional)
step 5> Now you are ready to launch your BITCOMET.
[NOTE: BEFORE YOU UNINSTALL YOUR BITCOMET BE SURE YOUR DOWNLOADED FILES AND TORRENT FILES ARE SAFELY STORED IN YOUR PC]
You may try these steps if you wish to …
Good luck.
edge :wink:
