Port Blocked(Bitcomet)
I had tried several methods and to no avail. The Yellow light stayed on.
First, I went into Windows 10 Control Panel, Second, Windows Firewall Advanced Settings , Third, Inbound Rules and New Rules, Fourth, I clicked on Port and enter port number from Bitcomet, Fifth, All the Connection, Sixth, Domain, Private and Public are checked.  Finally, Save with a new name.  I have still have the Port Blocked Yellow light on.
You need to set up using a fixed IP number and set the ports in your router to forward to that port.
Thanks for replying, however, I’m a newbie, please elaborate on how to set this up?
You need a fixed ip address on the LAN (Local Area Net) - usually in the form of 192.168.###.###. The third block is usually .0 or .1 and the fourth is any number greaterthan 1 and less than 255. Open a DOSprompy (command line) and type ipconfig to find out the IP number the router and use thatas the first three numbers.
Open the router(http://192.168.###.1) and look for port forwarding
It's better explained [here](https://www.lifewire.com/how-to-port-forward-4163829)
