OK, the port blocked (yellow) just started about a week ago after running open for quite a while. The task bar says ‘Blocked:71.X.XXX.XX:50081’. Going to CMD and typing ipconfig/all says the pc IP4 Address is 192.168.1.3 (Preferred). I have a Netgear R7000 router with the port forwarding set to this address and the port set to 50081 which aligns with he port setup in BitComet. I understand the 71.X.XXX.XX address is my isp address so what has changed and what am I missing?
If you go to canyouseeme.org and type your listen port number, do you obtain the same result?
I tried all of the ports listed and get the same result. Here’s the result for 25: Error: I could not see your service on 71.X.XXX.XX on port (25). I guess I don’t understand why this just started to be a problem This has the same setup for the past year ad now it’s blocked?
Just noticed an update for my Netgear Nighthawk. Downloaded and the port is now listed as open. Must have been a bug in my router software. Thanks for everything!
