port detection failed
(( port detection failed )) “gray light”
is this a real problem or not ? and if it real how i solve it ?
is it a pc or app problem or not ?
is it impressive error in download process ?
in the end i’m so sorry for prolongation … but please answer me
Grey means the test was not done, try retesting. Yellow light means our server cannot reach you because you are behind a router or firewall. Green means the server can reach you.
how i solve it ? please answer me
I have no idea what kind of system or connection you have, you haven’t read the instructions nor provided this information, so I can’t possibly know how to resolve the problem, but if I recall you can right click on the light and retry the test.
Also in case you may have missed the links posted all thoughout the forum, I doubt it’s possible you could have missed the first link in my signature below.
/monthly_04_2016/post-182603-0-45465400-1460731951.jpg" rel=“”>
i want to know you before 2 weeks bitcomet was work perfectly in all tasks ( include snapshoots and green light )
Edit: nevermind.
Try changing the port: Settings > Connection > Choose a random port
If you clicked on and followed the first link in my signature, then where are the answers to the questions?
Edit: nevermind.
thanks alot for your useful post now gray light switch to yellow (blocked) can u help me for swich it to green
If you aren’t willing to read the post I recommended and provide all the details we ask for, then we won’t be able to help you.
1- 1.40
2- 3G (vodafone usb modem Hilink E303)
5- win 8.1 pro 64x - built-in antivirus - built-in firewall
6- no IP filtering or protection software
When your port is blocked other peers cannot open a connection. You can read more about this here…
http://wiki.bitcomet.com/bitcomet_client_issues_and_possible_solutions#i_have_a_yellow_status_light_and_my_download_speeds_are_slow_what_should_i_do
In most cases this is caused by a firewall blocking incoming connections or a router not setup properly, but in your case you are using Mobile broadband which doesn’t allow remote computers to connect to you unless you connect to them first which is why we have this following info in the post I referred you to read…
2) What type of Internet connection do you have (3G , ADSL 3 Mbs, Optical Fiber, etc.)? If you are using WWAN or any type of connection that uses a cellular type of long distance wireless (not including your own personal Wi-Fi network) then be sure to mention this first.
We ask members to mention this first because if you must use mobile broadband you won’t get efficient use of BitComet. You can still use bitcomet, but connections to peers can only be made if you initiate the connection and if the other peer also has a blocked port, then no connection can take place, but if you happen to send a connection request to pees at the right moment when they are accepting peers, the torrent will work, it will just be slow.
The best solution is to go with a full bidirectional internet connection like fiber optic or cable broadband, or even DSL, and I’m not aware of any mobile broadband company that allows incoming connections.
You can’t unblock your listen port because Vodafone does not forward ports.
How does Gandalf know if Vodaphone will or won’t make exceptions?
Methinks he’s coming across as a bit cocky…
