Hi all… I know this is a popular challenge, and I’ve read many many posts about it before coming here. Hoping you can help - thanks in advance. BitComet is showing “Port Detection Failed” in the lower right corner, with a gray circle. If I “check again” from the right click menu, it stays gray and stays as “Port Detection Failed”. No torrents that are added begin downloading.
Details:
Network
Static IP address setup on local computer
VPN service is in use, with verified open port (canyouseeme.org shows *OPEN*)
Port forwarding setup on router
Everything else generally working fine... good speeds, Plex and other services all good
Troubleshooting
Have restarted both router and computer
Have verified port is open using several online services
Have verified that an exception is present in Windows Firewall, and have disabled firewall as part of testing with no luck
I'm medium-level proficient with this kind of stuff but get out of my depth pretty fast. Any ideas? Thanks again in advance.
Hi /profile/99035-rhubarb/?do=hovercard" data-mentionid=“99035” href=“/profile/99035-rhubarb/” rel=“”>@Rhubarb thanks for the quick response. When VPN is disabled, the port checkers show it as NOT open…
My VPN is [Private Internet Access](https://www.privateinternetaccess.com/helpdesk/kb/articles/how-do-i-enable-port-forwarding-on-my-vpn). I did follow their instructions for enabling port forwarding through the VPN, which was a toggle "on" in the settings, and connecting to one of a specific list of location gateways.
See screenshot of VPN settings panel below - any ideas?
UPnP is on in BitComet settings, and I tried both TCP and UDP in the VPN - still no luck. No torrents will download, and “Port Detection Failed” still showing with the gray circle.
Update - turns out the torrents I was using for testing were from a private tracker that has banned BitComet as a client. From what I gather the reason is related to the communication of true torrent stats which they use to enforce various ratios and limits. Bummer as I am a big fan of BitComet and it’s by far my favorite client so far.
When using a different (non-private) tracker, everything looks great and is flowing at ~10,000 kB/s. I am happy to have successfully cobbled together this setup with static IP + port forwarding + VPN, but sad to have to choose between the invite-only tracker and BitComet.
Thanks for the help and responsiveness.
That’s always been a problem with private trackers - you’re stuck with their settings. It’s probably down to the ill-founded rumour that BitComet ‘hammered’ trackers (it doesn’t, but that bit of FUD has been round for quite a while now).
