Hi all. My downloads were quite normal until a few days ago when I realised that my listening port has now turned yellow.
I’m running windows xp, using Bitcomet 1.03. My router/ modem is 2wire 2701HGV-E. I switched off windows firewall to test if the port will turn green but it did not. Other than that the only other firewall I have is the zonealarm free version, which I’ve already indicated bitcomet to be trusted server.
I tried to do nat port mapping following the instructions here and everything seemed according to what was written until I reached step 3 of manual NAT mapping. No ballon message appeared and no “internet gateway device” appeared.
Below is the info taken from my bitcomet. Not sure if it’s ok to post the full IP here so I’ve substituted the last 2 numbers with XX. Please let me know if it’s needed to solve the problem and I’ll repost it again.
Overall Tasks: Total:1 / Running: 1
TCP Connections: Established: 12 [MAX:Unlimited] / Half-Open: 2 [MAX:10]
LAN IP: 192.168.1.XX
WAN IP: 116.14.253.XX
Listen Port of TCP: 11508
Listen Port of UDP: 11508
Windows Firewall: Added [TCP opened, UDP opened]
NAT port mapping: Failed [uPNP device not found!]
Overall Download Rate: 1 kB/s Max Connection Limits: 50 per task
Overall Upload Rate: 14 kB/s, including LT seeding: 0 kB/s Upload slots: 7
Disk Cache Size: 10 MB (Min: 6 MB, Max: 50 MB)
Free Phys Mem: 256.67 MB (Min: 50 MB)
Disk Read Statistics: Request: 686127 (freq: 1.0/s), Actual Disk Read: 33563 (freq: 0.1/s), Hit Ratio: 95.1%
Disk Write Statistics: Request: 198835 (freq: 0.0/s), Actual Disk Write: 8509 (freq: 0.0/s), Hit Ratio: 95.7%
Total Downloaded: 4.14 GB
Total Uploaded: 13.25 GB
I need to add that I’m not exactly familiar with networking/ technical terms so please bear with me if I don’t seem to understand your advice.
Thanks in advance!
