Portfowarding
Whenever I do the portfowarding stuff, does this effect my internet security? :mellow:
That depends on your system config. But assuming you are just allowing the sharing of files within your BC download folder, you should be fine.
Okie dokie, Thanks :smiley:
www.portforward.com look up your router here. If you don’t have a router then you don’t need to portforward. Just give BC incoming and outgoing permission in your firewall aka server access. If you’re using the XP SP-2 firewall (its a good one.) then just add BC to the exceptions list and you’re ready to go. B)
