Problem about the display on peer panel
On a Torrent Panel, it display that I’m currently uploading with speed xxx Kbps
But on a Peer Panel, which it should display the detailed of peers, **it display nothing ** :frowning:
let’s see
http://img140.imageshack.us/my.php?image=bugbitcomet0je.jpg
Is this a bug ???
Thx in advance for your answers.
BitComet User
Yes this is a bug though i not sure what versions it affects and I’ve never experienced it.
Maybe it has to do with the Chat option since I’ve always had that disabled.
See Here
If you havent already I would suggest updating to Bitcomet v0.68
and if that also has this problem then revert back to v0.63
My 0.68 keeps hiding peers from my eyes… Takes care of their privacy %)
Update to 0.70.
