hi i have comet id (NEW)
but y the Points Remain Zero
and the Score up to (95)
like the Photos (why)
and how
1- up the (EXP)(0%)
2- up the level
THANKS
and how
1- up the (EXP)(0%)
2- up the level
THANKS
A score of 100 won’t bring you 100%.
You can view more info on the Comet ID ranking system in this Wiki topic.
ok but her see
BC Score = Points from online time + Points from uploaded Bytes.
1.Being online can generate 2 points per hour, with a limited maximum of 20 points, per day.
2.Uploading files continually, via BitTorrent protocol, can generate 1 point per 10MB, with a limited maximum of 100 points, per day.
3.Downloading files, via BitTorrent protocol, doesn’t affect the Score. The same applies to HTTP and FTP protocol.
4.The Score will be refreshed every 24 hours.
to up my points
and i online (6-8)hours on the day
and i uploading (98)mb of torrent
but the points(EXP) Remained zero
Why
Thanks
The points are found in the score not in the percentage.
The percentage represents the path from one rank to the next and therefore it goes up much more slowly.
The EXP was not correctly displayed, the team will fix it soon.
By the way, EXP doesn’t equal to score, as you have 95 points, you will need another 205 to upgrade, EXP tells you the percentage of points you earned in this level. For example, you have 95 points now, 95/300=31.8%, so your EXP should be 31% or 32%, definitely not 0%, but not 95% either.
yas i mean thereis aprooblem in the (EXP)
i will Understand How works the points and the score
Thanks
