Problem Seeding
I have uploaded a torrent I created on my computer. Unfortunately I accidentally removed it from the seed before I was able to start my download in order to complete the process to put it on the site. My question is how do I get my torrent which resides on my computer locally back into my seed list? Thanks in advance.
If I understand you correct, all you need to do is start the torrent just like any torrent.
You will need to have the complete files in your download folder
It will then scan (hash) the files and after is verfies they are all present, it will begin seeding.
This is the same proceedure you would use to reseed any torrent.
Finally got it later that night, thanks for the reply though :slight_smile:
