Problem with port listening
Hi everybody. I have problem with port listening. Bitcomet cant listen ports which i opened. Other torrent clients can see that ports are opened. how can i solve this problem?
I use Win7 and it has permission from firewall
for starters click on the “READ THIS before posting” topic that’s linked all over the forum.
ok i read it.
  1. i use bitcomet 1.27
  2. my connection is wan ethernet
3)i have Pirelli DRG A226G
  1. Os is Win7. only windows firewall
  2. speed test
and now???
You are connected via a combination modem and router, which contains a built-in firmware firewall. You will need to forward your chosen BitComet listen port through that firewall.
Some instructions, which supplement the User Manual, can be found here: http://portforward.com/english/routers/port_forwarding/Pirelli/DRG-A226G/DRG-A226Gindex.htm
These are supplemental to the manual. They do not replace reading and understanding the manual.
Also make sure bitcomet isn’t using a listening port used by another program.
