Problem with subtitle encoding
** Hello forum**
i installed the new MPCStar 5.2 but when i start any movie with arabic subtitle i can’t read anything because the characters are shown like symbols
plzzzzzzzzzzzz help :(:(:frowning:
This was discussed in the forum before and one of our tech staff had a solution. I don’t recall where, nor do I remember the solution, but I’m sure you could find it with a search.
ps. try this suggestion.
http://www.cometforums.com/topic/12796012-thai-subtitles
I’m not sure if it will work for you or not.
** none of those worked 4 me :frowning: **
**what should i do :frowning: it worked perfectly with version 5.0 and earlier but starting 5.1 and 5.2 it have a serious problem :frowning: **
Something on your system isn’t encoding the aribic subtitles correctly. I don’t personally know what has changed that could have caused this, but I’ll leave your topic open and perhaps another member can help you.
In the meantime, if a prior version works, I’d recommend reverting back to it. Any bug fixes in new versions should be listed in the release notes, so I’d check them before updating to future version.
