Problem with the downloading
Hi.. :slight_smile:
when i download by bitcomet 0.70 something strang happens for example:
" i am downloading files with size 500 MB and the program still downloading until 600 MB and the % still 97 and also there is no rubbish data in the counter"
so what i should do in this problem???
Thankssssssssssss
Are you downloading only part of a larger torrent?
NO
Now i am downlaoding a movie of size 1.37 GB and i had downloaded 1.02 GB and the % still at 70% and it should be at 78%
Note: i am downloadind all the files not a Part of the torrent
Thanksssssssss
PLZZZZZZZZZZZZZZZZZZZZZZZZ
ANSWERRRRRRRRRRRRRRRRRRRR
Regarding your second post, it could be normal to download more data then is reported in your percentage completed. Some pieces may need to be downloaded again if for example the piece doesn’t pass hash test.
I would not be concerned about that.
As for your torrent that stopped at 97%, this could be a bad torrent…
http://www.azureuswiki.com/index.php/Bad_torrents
Intentionally designed to fail, by anti bittorrent organizations. I suggest you read that article and see if yours meets that defination.
ps. sorry for delay in replying. Our staff are all volenteers and reply to posts when we are able. Sadly, this means posts can be overlooked from time to time.
