Problem with trackers
Hi, im having trouble with my downloads. The trackers they try to connect to dont give a respons. (UDP Tracker not responding). This applies to almost all my torrents. Some of them have trackers that respond (mainly http://explodie.org:6969/announce). I have checked every thing that is posted in your forum and on other sites, but nothing helps. Is there any solution you can suggest? If possible, any way to connect the working tracker to other torrents?
Im using Bitcomet version 1.37 64bit. Adsl connection with a Zyxel modem.
the torrents have to be registered on the tracker for them to work, you cannot add unregistered torrents unless it is an open tracker.
Usually when we see this problem it is a torrent that someone has carelessly added unregistered torrents and so much time is wasted trying to connect to them that it takes time before a good one is reached. It’s also possible they are busy and just waiting will resolve the problem.
