Uitandu-ma in documentul tau vad ca adresa ta LAN este 192.168.1.100, ultimul octet este 100. Deci mergi din nou la postul asta si urmand pasii de acolo, in loc de 55 scrii 100 si salvezi regulile.
Thanks for your understanding.
Looking at your document I see that your LAN IP address is 192.168.1.100, the last byte being 100. So, backtrack to this post and by following those steps, replace 55 with 100 and then save the new rules.
Tine minte ca trecand de la wireless la cablu schimbi placa de retea si fiecare avand adresa lor MAC, serverul DHCP din router le va da adrese IPv4 separate. Deci va trebui sa repeti pasii si pentru wireless.
Mai sigur le setezi tu cate o adresa statica la fiecare conexiune (prin fir/wireless) in concordanta cu setarile de deschidere a porturilor facute in router.
You’re welcome!
Remember that by switching from wireless to wired you change your NIC and each having their own MAC address the DHCP server in your router will give them separated IPv4 addresses. So you’ll have to repeat those steps for your wireless connection as well.
To be sure set both connections manually for their IP addresses to remain static in accordance to the port forward settings you made in your router.
Am trecut de pe cablu pe wireless si invers si adresele IP sunt diferite dar portul de ascultare ramane deschis indiferent de conexiune. Mai trebuie sa fac acele setari?
I switched from wired to wireless and backwards and the IP addresses are different but the listening port is still open regardless of what connection I’m using. Do I still need to make those settings?
Cand schimbi conexiunea da click dreapta pe bulina si selecteaza “Verifica din Nou”. Daca e tot verde la amandoua conexiunile nu e nevoie, dar situatia se poate schimba. E alegerea ta.
When you switch connections right click the status light and choose “Check again”. If it’s still green on both connections you don’t need to, but this situation can change. It’s your choice.
Salut. Am o problema cu download-ul. Nu mi se mai descarca nimic pe pc. Nici de pe steam nu pot sa instalez nimic si se aloca spatiu foarte greu pe disc. Ce as putea sa fac? Nu e din cauza internetului.
Hello. I have a problem with download. "I may not download anything on your PC. Neither the steam may not to install anything and shall be allocated space very hard on the disc. What can I do about it? It is not because of the Internet.
Fișierul poate fi mai mare decât spațiul liber pe unitatea hard disk. Efectuați un disc utilitarul de curățare (Puran Utiliies este un bun gratuit una) și să executați un disc verificați din Windows
The file may be larger than the free space on your drive. Run a disk cleaning utility (Puran Utiliies is a good free one) and also run a disk check from Windows
