problems closing prviewer
tried both the x close (upper right corner control) and using “file/cloe” to close the previewer (got tired of waitn for the video to luanch) and you get that dreaded not responding message. If you press end now it you also close the transfer box. Any ideas how to close this?
If your trying to preview a video that is not complete, then its best to wait till you have enough of it so that a segment long enough to play can be found.
If necessary, you can kill the process in task manager (control, alt, delete)
Although this can be a nice feature, it really should have a warning label on it “use at own risk”.
