erm i cant connect it says DHT not connected and my torrents arent downloadin how can this be fixed
i have the exact same problem.
sorry i can’t help, i’m awaiting help myself.
DHT is an alternate method of tracking a torrent, where the peers themself do the work of a tracker.
If you cannot download a torrent, the first step would be to ensure you have selected a torrent that is seeded. If there is no seeders, then you cannot download.
Dht must be enabled in your client, and the tracking website must allow for dht as well.
Here is a link for you to review…
http://en.wikipedia.org/wiki/Bittorrent
Edit: This problem was that the torrent he was using was not active (no seeders). Problem resolved
just make sure that you have dht enabled.
Options → Preferences → Connection → Enable DHT Network (this should be ticked)
