Problems with Windows Explorer
Hi All
I am having problems with my Windows Explorer.
I will be using it to look at files, or renaming files etc. when the “This program has encountered a problem and needs to shut down” window pops up.
This can occur just as explorer opens, or after a couple of minutes.
This is proving to be very irritating, as I dont seem to be able to do much.
I have tried looking around various forums and windows website, but to no avail. I have even reinstalled XP thinking there may have been a problem with the initial install. I had run V0.60 of bitcomet b4, then upgraded to
V0.65 (i think) where I started having probs. Prior to this, I didnt.
Below is a quick capture of the details for the problem from explorer
AppName: explorer.exe AppVer: 6.0.2900.2180 ModName: unknown
ModVer: 0.0.0.0 Offset: 03093206
Cheers
Jazz
This is not related to bit comet in anyway.
I will move this topic to our non-bit comet section.
Also, what version of Windows is this? I couldn’t begin to diagnose this from a forum post, but this is surely a windows problem.
If formatting your harddrive and reinstalling didn’t resolve the problem, then there is surely a conflict with something. Please describe exactly what you are doing when this happens.
Thanks for replying.
Im using Windows XP with SP2
All I am doing when using explorer, is looking at the contents of folders,
or renaming or moving the contents of folders.
I have also just downloaded another file browser program called XYplorer, and the same thing happens
Cheers
Jazz
