BitComet_1.67
file: C:\Program Files\BitComet\BitComet.exe
file: C:\Program Files\BitComet\tools\BitCometToastsNotifier.exe
file: C:\Program Files\BitComet\tools\Updater.exe
file: C:\instawb\BitComet_1.67\tools\UPNP.exe
file: C:\Program Files\BitComet\tools\VideoSnapshot.exe
file: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\BitComet (64-bit)\BitComet.lnk
regkey: HKLM\SOFTWARE\Wow6432Node\MICROSOFT\WINDOWS\CURRENTVERSION\UNINSTALL\BitComet_x64
startup: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\BitComet (64-bit)\BitComet.lnk
uninstall: HKLM\SOFTWARE\Wow6432Node\MICROSOFT\WINDOWS\CURRENTVERSION\UNINSTALL\BitComet_x64
p.s.: by Windows Defender Security Center Tray Icon, Windows10, v.2004
That post is irrelevant!
It is not about the installer, but after installation.
Please see [https://go.microsoft.com/fwlink/?linkid=142185&name=PUA:Win32/InstallCore&threatid=213927](https://go.microsoft.com/fwlink/?linkid=142185&name=PUA:Win32/InstallCore&threatid=213927)
It’s completely relevant - there is NO virus, Trojan or any other nasty in Bitcomet. The ONLY time a problem is reported is when the A/V scans the installer file and finds that algorithm
Was packagin Segurazo Antivirus also a false positive? That was a literal malware. No consent option from Bitcomet either.
You won’t get the ‘consent’ until the program begins to install and your a/v is blocking that. You HAVE to disable a/v, install andd then restart thje a/v.
It is NOT malware - it's an optional app but due to the a/v detecting the bundle installation, it blocks it.
I repeat - there is NO malware, there is NO Trojan and therte is NO virus. [The post](/topic/12801089-why-some-anti-virus-programs-dislike-bitcomet/?tab=comments#comment-81819) I gave tells you what is happening and why
