Question about CometBird
Hi, guys! I’m new at the forum. I’ve started using Cometbird yesterday because of problems with Mozilla. I’d like to know if there’s anyway to disable tab’s colors. Thanks.
@jose
theres another trick.i am sure u wil be fine with this.
install this addon
now open option on this addon.
then on GENERAL option select option COLOR ON DEMAND.then all u r tabs will be in PLAIN COLOR.
then under fading level option select as “no tab fading”
u can enjoy da tab fading option if u select max fading option.all inactive tabs woll be faded completely.it looks like SMART..
thank you so much.
