I haven’t used BitComet for a few months. I decided to use it today 6/11, but I got the error where it tells me to send an error report. I kept trying to open up BitComet and the error still pops up. I restarted my laptop, still did the same thing. So I’m thinking I need to uninstall BitComet then reinstall. My question is, will all my music files I downloaded from it be deleted once I uninstall?
I know in the past I renamed some of the music files on my desktop and when I tried to play the songs on iTunes it said file could not be found even though the file was still there. So even if I uninstall BitComet and the files remain on my laptop, will the songs still play when I redownload it? Or will I have to find over 14,000 songs (how many songs I downloaded) to download again?
I have 1.32 version, I think.
I don’t know what kind of internet connection I have. I’m using wifi at home.
My internet or modem or router aren’t the problem.
I have Windows 7. Firewall allows access of BitComet in the past. Have Norton antivirus. 32 bit.
Hopefully I can get some help.
