With the new bitcomet1.59 , I found something strange, when I quit the BC without a finished BT task. When restart it it would not connect to peers or seeders ,the tracker or dht return the seeds or peers normally,but not connect that is displayed like [0/335] .But when I manually rehash and restart the task ,it can connect and download . this happened over two tasks , I did not know where goes wrong .
Also a** suggestion** , now BT is blocked by many ISPs,almost useless without encryption ,so can you release the software with the **protocol encryption** default option set to **always** then maybe more people can normally using it .
Thanks a lot for providing such a wonderful software.
In regards to the need for a hash check, are you simply killing the program or using the ‘exit’ option? Even if you do a restart from the start menu, it will do a ‘soft’ exit and restart with no problem. Doing a ‘hard’ reset will cause problems with the downloads.
Regarding the second issue - all I can do is recommend you use a VPN
I quit using the ‘exit’ option and when it is count down ,I hit yes ,maybe it is caused by sth else. As the suggestion , I think ISP only block the protocol ,so there is no need to using VPN to circumvent ,plus VPN will limit the speed and causing extra expenditure.
A VPN doesn’t slow the system down - it simply hides your IP number so you can’t be traced.
It doesn't come free - you'd have to shop around to find the cheapest (it's against forum policy to make recommendations here). What you could try is to alter the internal port - you need to set up a fixed LAN IP (like 192.168.0.22) and allocate a port number to that in the router. Then set BC to use that particular port. That ***may*** help - no guarantees
