random restarts
Pentium d 960
Abit AW8D
1GIG Of ocs platinum
OCZ 520 Watt power supply
Evga 7900 GTX Super clocked
3 WD 2500 Hard drives
Sony dvd rw dl Rom drive
Windows xp pro
bit comet .76
My problem is as follows after I start downloads around 9 pm every night, somtime during the night the computer restarts. and when I open up bit comet the links all go to bitenova, even if I click on mininova.
If I’mnot running bit comet the computer will not restart during the night. I can run use next all night no problem and limewire also but bit comet will cause the computer to restart. I really like bit comet but I highly doubt that it is a compatability issue. this problem started 2 weeks ago, and bitcomet was running perfect before that with all the same hardware
I suggest you try a “Stable” version of bit comet.
http://bitcomet.com/doc/download.htm
or, if you like, perhaps version .77 will run more stable on your system.
