Ratio?
hi, what is rotio and how does it work? i want to keep it high what should i do? thanks a lot
Ratio is your upload - your download. Your ratio should be no less then 1:1 meaning you’ve given back as much as you’re shared.
How do you raise a ratio, keep uploading a file after you’ve compleated it’s download.
how do i keep uploading? just leave the file there unmoved right?
thanks
Yup.
