I was in the middle of downloading a file and instead of a green downpointing arrow, this was replaced by a red X but the file kept on downloading. Does anyone know what this is about?
Look in your tracker details, see if there is a message, perhaps saying tracker is offline. If so, you might be downloading using DHT, rather then by tracker.
Also, are any seeders present?
Also check if you have sufficient free space to download.
I kind of have the same problem ( Red X “This is a disk write error” ) , i have sufficient free space to download the file , the seeds and peers seem to be on line and the fire wall is not blocking it. Iv even tried down loading 1 file at a time and moveing the file i just downloaded to a new location and then get the next one with no luck as i got 2 files and then the red x came back.
There are some sreen shots of what i get. Im useing windows XP pro (sp2)
