hi i had restarted the torrent as u mentioned in one earlier post (for uploading the data) but the torrent file is not uploading(seeding) any data.
plz suggest…
plz suggest…
Please provide us some more detailed information so that we can better understand your situation and help you.
okay this is my situation
i had downloaded a movie but i had deleted it from torrent immediately without seeding and now i want to seed that movie.
i had downloaded that .torrent file (same as before) and again started the torrent [this all procedure is mentioned in earlier one of the post]...
and that movie is now on the torrent list of seeding but it is not uploading any data...
GOT it…
It will only upload if you’re connected to at least one peer that is seeking to download it. If other tasks seed normally, then it’s probably just a lack of interest in it so you should just wait until someone comes along and wants it. If this happens with all your tasks then it could be a problem with your connection, settings or firewall/router, none of which you’ve provided any information about.
