Rubbish in Special Situation
Hi all,
I have attached a screenshot to help describe the situation.
If you look at the attached screenshot you’ll see that I am only selecting some of the files in the torrent. When I do this, however, I seem to end up with a lot of rubbish. I’m wondering if this is a normal occurrence when downloading some, but not all, files in a torrent.
Can someone kindly explain?
Thank you.
/post-1304-1150997656.jpg" rel=“”>
Hi ptr,
This shouldn’t really occur, because in selecting files, all BitComet does is just select which packets should be sent to the user for download.
Try installing Peerguardian to lower the amount of rubbish data http://forums.bitcomet.com/index.php?showt…findpost&p=1442
Also, this may also be associated with peers within your torrent download having bad packets. Or even possible infiltration by govt agencies.
