Save path under Task Properties
I am currently using Bitcomet 1.24 and realised that the save path under Task Properties will not accept folders which are on stored on a network, e.g. \xxx.xxx.x.xx\personal\folder. Is this some kind of limitation/restriction in the new version as I was able to set my save path using \xxx.xxx.x.xx\personal\folder up until version 1.23?
Please advise.
Thanks.
It was probably not deliberate, but you can work around it by mapping the network connection as a named drive.
Thanks for the update. Just wondering if that will be fix in the next version though.
Cheers :smiley:
Hi bgunawan, this bug has been reported to the development team, it will probably be fixed in the version. Thank you for your support. :slight_smile:
