SCREEN RESET
Hi, It may be a matter of something ive pressed but when i watch a film on MPC it resets from fullscreen to small every five mins or so its been really annoying me now i have to manually stretch the boarders especially when i hook the laptop up to the tele .. like i said i can manually stretch it but id like to just click fullscreen and be done.
:mellow:
PLEASE HELP!!!
Are you talking about mpcstar or mpc?
Also, are you running it in full screen or just stretching the window to fill the screen?
Do you have a screensaver enabled? it sounds like something is running that takes the “focus” away from your media player forcing it to run in the background. Usually when an app is run in fullscreen it disables things like screensavers and other apps from causing this.
