I just installed Bit Comet 1.36
I have Fios with a Router.
How do i see the list of Seeder’s at the bottom of my screen ?
/monthly_08_2013/post-5771-0-61215300-1375713479.png" rel=“”>
@ desgnr > I think you cant see in that column but you can see it in column SUMMARY & for your info, i used only 3 coloumn. (1) summary (2) file & (3) peers. these are the important coloumn that helps you to determine down/upload speed, seeders/peers & file that related to the top coloumn
You can see a list of peers if you select a task in the top pane, without selecting a task it won’t show task specific columns. You can also “right click” on any of the tabs and select which columns you want displayed.
