Hi My bcomet was 0.60 never had problems before. I could go to interface inside bc in search the sites. But now I’ve reinstalled the 0.60 in same problem I can’t search through the sites. I don’t have the problem searching through IE. I’ve also unistalled the full program including folder on c drive. Restarted computer and installed 61 same thing. Have read form in did what it said nothing need help. Second question I’m also downing a movie that’s 1.3gb 4 peers attached 0ne has same amount as others with other torrent programs have more 97.8 percent 100 percent but I seem to just be getting the download from the one with 3.4 percent they get more of it than I get it from them. can you help? Everythings set up right firewalls fine ports open in working connection on computer set for open connections fine. all other torrents fine when I get them. P.S Opened bc site to download new set.exe and it took from their site 57.minutes. by the way I’m on a cable setup. Thanks for any help. milk
You should be using version 0.70 and go through our settings guide to make sure everything is properly configured. You should also check your firewall settings.
Hi Thanks For Replying. I really have no other problems than I can’t search the torrents sites on the side of bc when it’ opened. Other problem deleted file. Firewall is fine have both remote and local. My friend and me had the same program runing before and it clashes. So they changed theirs.You can’t have the same program running through two differant computers. I like .060.061.exe milk
