Can bitcomet add a field to show how much data is uploaded or downloaded in current session.
Similar to qBittorrent.
Do you mean something like this?
Can you clarify what is Total Downloaded / Total uploaded mean? Is it for today?
I just updated to BitComet 1.80 a few hours ago.
It means what it says - the total data uploaded to other people and the total data you have downloaded.
Total is all data since installation: this session is data since program start.
Total will reset to zero if you re-install the app
Thanks for your clarification. This is what I want. You can close this request.
