i no kvcds are for normal cds
but some files are to big for these so is there away you can put them onto dvd discs
or is there somewhere where you can download movies in a format where you can burn to dvd
thanks in advance
jim
thanks in advance
jim
A KVCD is made to fit on a normal sized CD. If it doesn’t then it’s not a KVCD. Please explain what is happening and what you’re trying to do.
