Single outgoing port
Hello there!
I’ve changed clients from Azureus to Bitcomet and I miss a feature I was able to use in Azureus: binding the outgoing peer (not DHT) connections to a single port. This feature helps with NAT router instability by preventing the client from opening too many outgoing ports at the same time, but the client is still able to maintain a lot of peer connections.
Hi Consular,
That’s a good idea. Thank you.
