I am facing slow internet browsing when my bitcomet running.
Sometime I received error webpage not available.
Any settings I should change for in order to view internet website correctly?
Yes, check the “READ THIS before posting” so you know what info to provide and make sure to post results of a speedtest.
This is also covered in the Wiki FAQ (link on top of the page).
I am using Bitcomet 1.28 with win7.
After changing network.max_connecting_connections from 0 to 10, I think I can surf web now.
My network.max_connections still 0.
In this setting 0 = unlimited
Since using the unlimited setting interferes with your browsing, you just need to find the highest setting your network connection can tolerate. We could have been of more help to you on this if you had read the “READ THIS before posting” topic, but since we know nothing about your connection, instead of fixing the problem, we can only have you adjust your connections to work within the problem.
10 is an extremely low number of max connections. I would try 100, and if it works well, adjust it higher until you find the limit your connection can support, then backup a couple steps to make sure you don’t approach that limit.
These idiots who can’t be bothered to provide information really piss me off.
TUUS, the parameter he’s referring to is controlling the number of half-open connections.
I think you misread it, and took it for the other one which controls the number of established connections, since they look alike. ![]()
So, in this case 10 is not a too low value.
@sychern: Except, AFAIK, 10 is the default in BitComet (i.e. when the value is set to 0 which means “automatic”). So, you don’t seem to have really changed anything.
But if you feel it works better now, well, leave it like that… perhaps the placebo effect works on computers too, who knows? ![]()
You’re right… and I do admit I didn’t read it carefully, however I was understandably dismayed by the lack of specific information we asked for and assumed that he changed the one setting that “could” have made a difference.
I still am wondering if it wasn’t the “network.max_connections” limit he changed, since changing that from 0 (unlimited) to a very restrictive number (10) would stop a weak router (actually we still don’t even know if he uses a router) from crashing.
Anyway, when the member requesting support provides us with the information we need to “accurately” diagnose this, we will continue, but we cannot continue to offer suggestions or make assumptions when we don’t even know what hardware and software they are using.
Please reply with ALL the details asked of you or this support request will be closed.
ps. If there is something you don’t understand, then you may ask, but ignoring something either because you don’t understand it, or you don’t feel it’s important won’t be tolerated here. We are all volunteers who donate our time to help BitComet users and since we have clear and concise rules for posting support requests, we shouldn’t have to ask for info that you’re required to provide, and definitely should NEVER have to ask twice.
Wiz, this is not correct…
My system defaults to a value of 200. Windows xp sp2/3 and vista sp0 will default to 10 because of the tcpip limit imposed. *info from observation that I believe accurate, but you can add it to the list of data that needs to be confirmed if you have doubts.
You mean that BitComet has by default a limit of 200 on Win 7? AFAIK Vista doesn’t have any limit on half-open connections too, (I’m referring to Windows settings not BitComet).
I said 10, because I remember that’s the answer Lucy got me from the team, a while ago. I posted what I thought it was a bug (I couldn’t lower the value of this option below 10 in BitComet) and the team responded that this is the minimum allowed. Then when I installed the next stable release, it defaulted to 10.
I guess we should test this with some ZIP versions of BitComet.
