Im having problems with bitcomet i get a slow dl, 15+kbs :/, im using a westell 6100 modem and i saw in fact that i suppose to set gobal connections to 100 but i dont know how? help please?
Here a copy of logs if it helps
Default tracker optimization rules file loaded.
IP rules file: ipfilter.dat loaded, 0 entries.
Start Listening at TCP Port:9864
Start Listening at UDP Port:9864
BitComet 0.70 is running on:
CPU : AMD Athlon XP 3000+ 2166 MHz
RAM size : 1,023.48 MB
OS Version: Microsoft Windows XP Professional Service Pack 2 (Build 2600)
Windows XP WF Status: TCP Port is not opened in Windows Firewall.
Windows XP WF Status: add TCP port in Windows Firewall Succeed.
Windows XP WF Status: UDP Port is not opened in Windows Firewall.
Windows XP WF Status: add UDP port in Windows Firewall Succeed.
Update Local IP: 192.xxx.x.xx
Windows XP ICS Status: cannot find working ICS.
Favourite sites file is updating from http://100.bitcomet.com/bitcomet/v0.64/fav/fav_en_us.xml
Favourite sites file updated to .C:\Program Files\BitComet\fav\fav_en_us.xml
Windows XP UPnP Status: device not found!
UDP tracker report: WAN IP = 70.xx.xxx.xxx
Connected to UDP helper tracker on 2006-08-10 17:41
