Snapshot Icon problem
Hi why the snapshot icon is like that? I think this is not the normal snapshots icon
/monthly_08_2016/post-190503-0-24259400-1471235824.png" rel=“”>
could be a codec problem, you system may not have the proper codecs to display the snapshot, or perhaps it couldn’t be downloaded.
Are you using any ip filters?
could be a codec problem, you system may not have the proper codecs to display the snapshot, or perhaps it couldn’t be downloaded. Are you using any ip filters?
IP Filters? Do you know where to download proper codecs?
Do you use PeerBlock, PeerGuardian, Protowall or similar apps that use IP blocking lists?
As for codecs, if you don’t understand this, then it’s not wise to mess with it especially since we don’t know the cause for your snapshots not displaying, it could be that they are simply not available.
No I don’t use it. This appear since someone help me to remove some malware using farbar tool
sounds like it removed something it shouldn’t. Try removing and installing bitcomet.
Already did that
I suspect the problem is with Internet Explorer then.
