Some help with Nero is needed.
Hey,
i have very little comp skills as you can tell they i am asking you a question in a reply. i wont know where to look for ur reply so could u please email a reply. i_like_fu_king@hotmail.com. my question is that i looked at my remaining space left on my hard drvie and then i burnt 11 discs with Nero and now 1.5Gb have been used up. How do i delete all the data from my comp the Nero has created? It will be much appreciated if you reply.
Hey,
could you tell me how to burn with nero?
i have it and it says incompatible
thanks Ritty
thanks Ritty
open nero and where it gives the choice of what you want to do click on make a DATA CD or DATA DVD. then burn to cd or dvd. either of these will work for movies. the only difference is you can fit about 5 movies on 1 dvd disc.
