some problem
When I try to install BitComet v1.7, it’s wont start to install.. only shows “Installer Language” and after that nothing… I even tried to install new Beta version, but its same. Why?
I had v1.6, but I accidentally removed it. -.-"
You haven’t provided enough information for anyone to be able to help you.
:mellow: Don’t mind me; but isn’t it the same issue ?
Can’t install 1.17
well, when I run bitcomed installer (v1.7 or beta version) here only comes “Installer Language” (where u can choice language) and when I press “OK” nothing comes. (here should come where to install and installing window). But I don’t get anything.
alfa206, did you select the “Install files for complex script and right-to-left languages”?
It might be the same issue, DIABLO, if Alfa206 is running Win7. But we don’t know that because Alfa206 didn’t say – didn’t provide the necessary and requested information, like which OS he’s using. You’d think anybody would just know they needed to tell us stuff like that, but alas …
im using win7 64bit OS, but I had v1.6 installed, but got removed accidentally -.-"
Then read the topic DIABLO linked you to.
I know.. but when I “Run as administrator” I get “Please run this installer with non-elevated user privilege!”. And when I just run, I only get select language. (I’m Admin in my PC)
What’s your UAC status and your account type?
According to the table in our wiki, I think you have UAC enabled. Still my question, What language did you select?did you select “Install files for complex script and right-to-left languages”?
And did you try to install by press Shift and “Run as different user” from right-click context menu but login administrator account"?
please,turn off UAC.
